1990 Dodge Daytona OUT OF SYNC
131,000 MILES • 4 CYL • FWD • MANUAL
BIKERBRUCE69
some times if shift to fast lose all gears but what I put it in or somtimes just 1,3,od will work. Hitting a bump in the road somtimes frees up and lets me use all gears. yesterday shifty to od on the interstate made me lose all other gears. I could move shifter but all other positions were nutral with the cluch out. after ideling tell warm today I evetuly got all 5 gears back. how does cable shifting work? do I need to lube or is it a worn out spring?
Dec 29, 2009 at 12:59 AM
DOCFIXIT
  • 18,828 POSTS
Think problem is in shift housing either worn cross over shaft or lock pin.
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_288.jpg
Dec 29, 2009 at 1:23 AM
