1990 Dodge Daytona lights
250,000 MILES • 4 CYL • FWD • MANUAL
SILVERCODY
hi my daytona has the lights that go up and down but they dont move since i bought this car. so i took around and noticed they are attached to motors and are wired in. so i was wondering how too get them too move. i could not find a switch or a fuse for the lights. but on the dash there is a botton that is broken. its on the bottom of the left hand side near the signal switch, is the for the lights if you know thanks..
Apr 30, 2009 at 2:03 PM
  • 110,248 POSTS
Actually, the motors were actuated by the headlight switch. You need to check to see if the motors are getting power when the headlights are turned on. If they are, the motors are bad. If not, chances are the headlight switch is bad.
Oct 20, 2009 at 3:50 AM
