1990 Dodge Daytona daytona wont start
HOOTNICK
  • 6 POSTS
1990 Dodge Daytona 4 cyl Automatic
car worked fine the night before and in the morning nothing. At that point plugs, batt 2months old. Now I have put in new starter relay,new starter solnoid, and a used starter. NOTHING??? I turn the key (aux) and the lights turn on no problem and when i turn it over nothing no dimming of the lights. I just dont know what next could it just be the low batt. Other than that the only other thing is the connection wire from the batt to the solnoid (on the solnoid end) The rubber cover on the connection a chunk is missing but the connection is clean and looks ok and is connected. HELP. please help
Mar 19, 2009 at 9:21 AM
  • 75,988 POSTS
Check fuse no.55 40amp, automatic transmission switch and ignition switch.
Mar 19, 2009 at 9:31 AM
HOOTNICK
  • 6 POSTS
Ok that would make sense but where is the fuse i looked in the car nothing doing there. i have no manual to locate the fuse/switch
Mar 19, 2009 at 10:50 AM
  • 75,988 POSTS
Below is your start EWD
https://images.2carpros.com/forum/automotive_pictures/12900_starter_daytona_1.jpg
Mar 19, 2009 at 1:21 PM
HOOTNICK
  • 6 POSTS
For real thankyou so much.....But the picture is only 2x2 on the screen and when i blow it up you cannot read any thing. I even tried the rock the car last night thinking it might just be a linkage problem but nope, so it really sounds like you are so on the right track ......I just wish i was on the same track as you. My hope is that it has to be something small causing this rather painfull process. Although to you again thanks.
Mar 20, 2009 at 2:05 AM
  • 75,988 POSTS
Give me your email addy maybe the diagram will show better.
Mar 20, 2009 at 8:51 AM
HOOTNICK
  • 6 POSTS
hootnick@hotmail.com thanks again.
Mar 21, 2009 at 3:00 AM
HOOTNICK
  • 6 POSTS
Raz so freaking sorry, your name and email must have went to junk mail write who its comming from in the subject if your was go go hahaha then ya junked sorry for me really i missed it thought it was something it wasnt and never opened it try again ill be more aware this time thanks again.
Mar 22, 2009 at 7:59 AM
