1989 Dodge Daytona no low beams and wipers
120,000 MILES • 4 CYL • FWD • MANUAL
OLSON2624
hi, i'm currently having problems with my dodge daytona. I have replace all the relays in the fuse box plus the fuses. I have hi beams but no low beams(headlights), and the windshield wipers do not work. It took some slight water damage due to the t-tops leaking. any advice would be appreciated. thanks.
May 26, 2010 at 8:27 AM
  • 110,248 POSTS
I would recommend starting with the multi function switch on the steering column. Since both items are run through that point, that is most likely the problem.
Jun 4, 2010 at 3:38 AM
