1989 Dodge Daytona ES running to rich
CJACD
Car is running too rich and idles rough, already changed injector, tps, and fuel pressure regulator, checked vacuum leaks, checked coolant temp sensor, need to know what to do next
Mar 13, 2006 at 2:44 AM
MIAMIHURRICAINES2049
  • 10 POSTS
have you checked motor mounts my dayton was idleing rough and i found the front mount under the radiator was broken. also check the oxygen sensor that might cause the rich problem
Jun 12, 2007 at 10:23 AM
