1988 Dodge Daytona no fuel pump and injection coil
1988 DODGE DAYTONA
120,000 MILES • 4 CYL • FWD • MANUAL
KURBSTER
I have 88 Dodge Daytona Shelby Z 2.2 turbo. I was restoring it until my fusible link went out so i replace them and now i have no spark and no fuel pump. I check everything on the car and I replaced the coil and fuel pump also the ASD still no power to them. I dont know what happen since it was running before than its kinda odd it did that for me so plz help me
Jun 21, 2010 at 2:23 AM
CARADIODOC
  • 34,381 POSTS
Hi kurbster. Welcome to the forum. Start by removing the ASD relay and using a test light to check for battery voltage at one of the terminals in the socket. As I recall, there should be battery voltage on a second terminal when the ignition switch is turned to "run".
caradiodoc
Jun 21, 2010 at 3:31 AM
