2002 Dodge Dart don't idle
IOWA_MALE
Engine Performance problem
2002 Dodge Dart V8 Two Wheel Drive Automatic
2002 dodge dakota engine don't idle it goes from 500 rpm to a 1000 rpm
i had a check engine light codes p0121
that code says its Throttle Position Sensor
when i was looking under the hood i found a bad vacume hose replaced it
unhooked the batter light went off but know it will not idle right
Apr 21, 2009 at 12:54 PM
  • 75,988 POSTS
Probably bcuz you disconnected the battery and the computer at this time going thru a releaning process.
Jun 3, 2009 at 11:29 AM
