1975 Dodge Dart
62,000 MILES • 6 CYL • 2WD • AUTOMATIC
DARWAY65
shakes, thumps/bumps, and wobbles when driving. Continues even when in neutral and moving forward. Front drivers side tire has thick black grease dripping from it when tire was removed to try to locate area of problem.. Left front wheel drum smoking and extremely hot. Any ideas what could be causing this? Thanks, Darlene
Sep 18, 2010 at 8:26 AM
HMAC300
  • 48,601 POSTS
the thick greas may be form the ball joint leaking. It's best to get the front end check out by a professional. the brake drums will get hot ,but you may have a wheel cylinder leaking so best to get that checked as well....
Oct 1, 2010 at 1:21 PM
