1974 Dodge Dart Shocks
11,200 MILES • V8 • 2WD • AUTOMATIC
RICKTHESTICK
My Dart is 2 inches lower in the rear drivers side. I put Air shocks on with separate lines hoping to put more air in on lower side to even it up. didn't work. When I put air in lower side the other side also goes up. Is there a different type of shock I can use? I realize that I probably have a weak leafspring but I really do not want to change it, Want to go an easier route.
May 22, 2009 at 1:22 AM
TWO66MHZ
  • 17 POSTS
[quote:3eceddaf5e="rickthestick"]Suspension problem
1974 Dodge Dart V8 Two Wheel Drive Automatic 112,00 miles
My Dart is 2 inches lower in the rear drivers side. I put Air shocks on with separate lines hoping to put more air in on lower side to even it up. didn't work. When I put air in lower side the other side also goes up. Is there a different type of shock I can use? I realize that I probably have a weak leafspring but I really do not want to change it, Want to go an easier route.[/quote:3eceddaf5e]
You probably will not find an easier route, pumping up air bags unevenly could also cause some cornering differences, you were essentially are weight jacking the car. If a spring is sagging just replace it.
Nov 4, 2009 at 2:33 AM
