1965 Dodge Dart Will not stay running
OLDDMAN
Electrical problem
1965 Dodge Dart V8 Two Wheel Drive Automatic
Engine will start then stop after a few minutes. Then it will crank, but not start. Then it will start and then stop or it could run fine for a day or two and then the problem happens again. When it cranks but does not start there is no current to the coil. Have checked coil, replaced balast resistor, ignition switch. What do I do to find problem?
Feb 22, 2009 at 2:25 AM
  • 110,248 POSTS
Hi:
Is there power to the resister? Make sure there is power when cranking and then check the resister with the key in the on position.
Mar 9, 2009 at 6:38 AM
