Will not start
100,000 MILES • 4.7L • V8 • 4WD
BONITAM
The truck would run well then stall at a light and now it will turn over but not start.
Oct 23, 2017 at 9:10 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
First thing is try a new fuel filter. Then if the problem still happens, have the trouble codes read. Listen if the fuel pump runs or not when the key is first turned to run, for about two seconds. If not, check the fuel pump fuses and if okay, try a new fuel pump relay and check it again.
Oct 23, 2017 at 9:18 AM
CARADIODOC
  • 34,414 POSTS
What have you checked so far? Was the battery recently disconnected or run out? Have you checked for spark and fuel pressure? Do you hear the hum of the fuel pump for one second when you turn on the ignition switch? Have you read the diagnostic fault codes? Do you know how to do that yourself? Will the engine start and run if you hold the accelerator pedal down 1/4"?
Oct 23, 2017 at 9:20 AM
CARADIODOC
  • 34,414 POSTS
Forget the fuel filter. That is a dandy suggestion for other brands of vehicles, but other than for diesel engines, you will never solve a crank/no-start or a running problem on a Chrysler product by replacing the fuel filter.
Welcome to the forum, PATENTED_REPAIR_PRO
Oct 23, 2017 at 9:23 AM
BONITAM
We have not gotten it home yet. it stalled downtown this afternoon.
Oct 23, 2017 at 9:25 AM
  • 55,721 POSTS
This sounds like a crankshaft angle sensor that is going out. When the engine wont start does it have spark? Here is a guide to show you how to check
Here is a guide to help you see what you are in for when changing a crankshaft angle sensor.
Here is what it will be like on your car (below) I included all three engine so it will help others
Please let us know what you find. I'm interested to see what it is.
Cheers, Ken
Oct 25, 2017 at 9:25 AM
