Thank you for your time.
1991 Dodge Dakota Hard Start Clicking
Thank you for your time.[/quote:0c26723459]
Check the starter relay if it has one
For the battery drain-disconnect the batt. positive post put a test lite in between if you have a short the lite will come On-now start removing fuses one at a time till the lite turns off-that is where your trouble circuit is. In the event you remove all the fuses and its still there-remove the batt wire at the alty-if the lite turns off-the alty is the problem.
Suggested Repair
Check the starter relay if equipped. For the battery drain, disconnect the positive battery cable, place a test light between the cable and post, and pull fuses one at a time until the light goes out to identify the circuit. If it stays on after all fuses are removed, disconnect the alternator battery wire; if the light then goes out, the alternator is the problem.
Conversation Summary
The owner of a 1991 Dodge Dakota reports intermittent hard starting, clicking, and a slow battery drain that returned after the battery was replaced. A shop said the alternator was not the cause but could not find the drain, and others suggested the starter. The expert recommends checking the starter relay and tracing the drain with a test light and fuse pull, including the alternator feed if the fuses do not isolate it.
