1990 Dodge Dakota High Idle in Gear
ERICB.
i have a 1990 Dodge dokata v6, 3.9 liter , it has over 1000 miles on it, anyways ,when i put it in gear it kinda jumps and burns out , i have my foot on the brake too when i change gears ,my friend said its ideling too high is that the problem, would you give me some tips to how to get it fix and how much it would cost i would appricate it.
ERIC BUNCH
[img:358e658138]http://www.2carpros.com/forum/automotive_pictures/108004_1403312765_m_1.jpg[/img:358e658138]
Oct 15, 2007 at 3:56 PM
  • 75,988 POSTS
Could be a vacuum leak, a problem with the idle air control valve/stepper motor, throttle position or MAF sensors.
Oct 15, 2007 at 9:22 PM
Suggested Repair
Check for a vacuum leak and inspect the idle air control valve or stepper motor, throttle position sensor, and MAF sensor, which can cause a high idle and a jump when shifting into gear.
Conversation Summary
The owner of a 1990 Dodge Dakota 3.9L says the truck jumps and spins the tires when shifted into gear even with the brake applied, and a friend suggested the idle is too high. The expert identified a vacuum leak or a fault in the idle air control valve/stepper motor, throttle position sensor, or MAF sensor as possible causes. No repair cost was discussed.
