P0748
LRWARCHILD
Hello, I have a 2002 Dodge Dakota truck with 103,000 miles. It has a check engine code of P0748. It says short in the governor pressure control. Nobody seems to know what this means. Can you help?
May 19, 2007 at 4:11 PM
  • 75,988 POSTS
[quote:879440b8a4="lrwarchild"]Hello, I have a 2002 Dodge Dakota truck with 103,000 miles. It has a check engine code of P0748. It says short in the governor pressure control. Nobody seems to know what this means. Can you help?[/quote:879440b8a4]
I would recommend a check on the vehicle speed sensor it takes the place of the governor in a conventional hydraulically controlled tranny.
Further the computer uses this signal to control shift points and the operation of the lock-up clutch
May 19, 2007 at 7:41 PM
LRWARCHILD
[quote:a1e346cfb0="rasmataz"][quote:a1e346cfb0="lrwarchild"]Hello, I have a 2002 Dodge Dakota truck with 103,000 miles. It has a check engine code of P0748. It says short in the governor pressure control. Nobody seems to know what this means. Can you help?[/quote:a1e346cfb0]
Further the computer uses this signal to control shift points and the operation of the lock-up clutch[/quote:a1e346cfb0]
Thanks of the fast reply. Is the speed sensor on the top of the rear differential?
May 20, 2007 at 10:57 AM
  • 75,988 POSTS
[quote:66282c4ca4="lrwarchild"][quote:66282c4ca4="rasmataz"][quote:66282c4ca4="lrwarchild"]Hello, I have a 2002 Dodge Dakota truck with 103,000 miles. It has a check engine code of P0748. It says short in the governor pressure control. Nobody seems to know what this means. Can you help?[/quote:66282c4ca4]
Further the computer uses this signal to control shift points and the operation of the lock-up clutch[/quote:66282c4ca4]
Thanks of the fast reply. Is the speed sensor on the top of the rear differential?[/quote:66282c4ca4]
Should be at the tail shaft of the tranny.
May 20, 2007 at 12:01 PM
LRWARCHILD
[quote:df89ea8dfb="rasmataz"]
Should be at the tail shaft of the tranny.[/quote:df89ea8dfb]
Ok so I went ahead and replaced the speed sensor. That didn't fix the problem. My code is still there, and my power loss is still significant. It's still got no take-off. Once you hit a freeway speed, it's got pretty good pick-up, but it's like it doesn't have a passing gear. I did disconnect the battery after changing it to reset the system. Oddley, enough, it got rid of all my other codes (0132, 0420, 0442, 0456). However, P 0748 is still there. Thanks ras, for following up with me.
May 20, 2007 at 1:59 PM
