1997 Dodge Dakota No Power Steering
JBHARR1
97 dakota, 3.9L, 180,000 miles
Just drove to a buddy's house and everything worked fine. 2 hours later when i went to leave I had no power steering. I could turn the truck but had to really put my weight into it. All my guages are normal. When I got home, it appeared that my belt is working normally and the fluid level was where it should be. Any ideas at what could be my problem? It is -7 up here, did something freeze on me?
Feb 3, 2007 at 3:07 PM
KNIGHTRIDERKITT2000
  • 93 POSTS
sure you didnt blow a fuse, if not a fuse then the power steering pump might have gone out
Feb 4, 2007 at 9:29 AM
SERVICE WRITER
  • 9,123 POSTS
I can't help but wonder if it is so cold that a seal is not expanding in the ps system preventing a preussure build up. I don't see a fuse relationship whatsoever. I would see about getting it into a heated environment to see if that changes anything.
Feb 4, 2007 at 11:12 AM
JBHARR1
thanks for suggestions. took it to local garage this morning and they said there was something broke inside the pump. replacing should fix it.
Feb 5, 2007 at 2:40 AM
Suggested Repair
Replace the power steering pump. A shop found an internal pump failure; belt and fluid level were normal, and a fuse is unlikely.
Conversation Summary
A 1997 Dodge Dakota suddenly lost power steering in extreme cold while the belt, fluid level, and gauges appeared normal. One reply suggested a fuse or failed pump; an expert doubted a fuse and suggested warming the truck in case a seal was not sealing. A local garage later found something broken inside the pump and said replacement should fix it.
