It sounds to me like your exast manafold is loose or the gasket is blown. The backfire and pop is usually cold air getting in to your exost, It could also be blown head gasket or cracked head, as with both they will expand when hot and it will generaly get better. If thats the case it will only get worse. If you have white smoke coming out your exost when it is cold than it is a head gasket. Check your oil and make sure there is no bubbles (water) on dip stick, and no sluge in your antifreeze.I hope this helps. JACK
SPONSORED LINKS
Monday, July 16th, 2007 AT 9:25 PM
