1992 Dodge Dakota, 3.9 ltr, 125,000 miles,
Is there a valve or something underneath the heater housing to adjust the flow of water going through the heater core? If not, can I disconnect both hoses going in and blow it out with air? If not, are there any diagrams showing the easiest way to remove the heater core without taking out the dash?
Thank you,
Larry
PS. I would donate, but heater core, water pump, and the sub-zero temp here has cost me every dime I got. I will get you next time.
Thank you,
Larry
Jan 22, 2007 at 10:51 AM
