1989 Dodge Dakota Cranks No Start
MOTORGUY007
  • 7 POSTS
My 1989 Dodge Dakota, 3.9L V-6, 5 sp manual, 230,000 miles will crank but not start. I can pressure up the fuel injection system by running the fuel pump manually and then it starts. Fuel pump (with intank filter) has been replaced, New Fuel lines, and Fuel Filter, Could the Pressure regulator be causing the fuel not to get to the injuctor?
Feb 21, 2007 at 12:07 AM
2CARPRO JACK
  • 11,533 POSTS
Check the fuel pump relay.
Feb 21, 2007 at 12:09 AM
MOTORGUY007
  • 7 POSTS
Sorry, I missed telling you, the relay was changed as one of the first things, it shows energized at the pump for about a second and then kicks out...I have read that this is normal.
Feb 21, 2007 at 12:12 AM
2CARPRO JACK
  • 11,533 POSTS
Could be the ignition switch? Check your manual wiring diagram to see where else the power to the pump comes from.
Feb 21, 2007 at 12:15 AM
MOTORGUY007
  • 7 POSTS
According to the diagram I have it shows a green wire with a black stripe powered from the auto shutdown relay directly to the fuel pump. The wire appears to check fine. I hooked a test light up to the wiring at the tank, ignition on, lights for about a second and shuts off...click heard/felt at the relay.
Feb 21, 2007 at 12:21 AM
2CARPRO JACK
  • 11,533 POSTS
Auto shut down relay been replaced? Might seem ok but when a larger draw is pulled on it , could be weak
Feb 21, 2007 at 12:22 AM
MOTORGUY007
  • 7 POSTS
yes, new from crysler, Should it stay energized longer than a second or two if the engine is not started?
Feb 21, 2007 at 12:25 AM
2CARPRO JACK
  • 11,533 POSTS
No, they turn off after a few seconds. Does the PCM have any power connection to the pump? Dodge was great for having the PCM control things it didnt need to
Feb 21, 2007 at 12:36 AM
MOTORGUY007
  • 7 POSTS
Not that I am aware of. Does the Fuel pump for those have a check valve in it to keep the fuel system pressurized? I did read in my manual about a fuel pressure regulator on the back of the injector,,,could this be letting the fuel run back to the tank and the 1-2 seconds run time when the key is turned on not be enough to get the fuel back to the injector? The computer is not storing any trouble codes that should be causing a no start situation. It typically shows a 12 Battery disconnected, 34 No speed sensor signal.
Feb 21, 2007 at 12:46 AM
  • 75,988 POSTS
Jack mentioned the ASD relay-that thing too-powers up the coil-suggest you look for spark too.
Note: The PCM controls the ASD relay
HTH-Good Luck!
Feb 21, 2007 at 6:31 AM
MOTORGUY007
  • 7 POSTS
Got plenty of good hot blue spark, When I run 12V straight to the pump for a few seconds (to pressure up the system) it will start and run perfectly. After it sets for a few hours it will start if I re-pressurize the system.
Feb 21, 2007 at 6:36 AM
  • 75,988 POSTS
You begining to make me think! pump-okay lets check the pressure regulator and a check valve at the pump
Feb 21, 2007 at 6:45 AM
MOTORGUY007
  • 7 POSTS
I have not located a check valve anywhere in line (at least from the pump, to the outside of the tank, Is there a check valve located in the pressure regulator? According to my book it is on the back of the injector possibly in the fuel inlet? I really appreciate the time you have taken...this one is driving me nuts!
Feb 21, 2007 at 6:50 AM
Suggested Repair
Check the fuel pressure regulator and the fuel pump check valve for leak-down that bleeds residual pressure after the brief key-on prime cycle.
Conversation Summary
A 1989 Dodge Dakota 3.9L cranks but will not start unless the fuel system is manually pressurized; after sitting several hours it needs repressurizing, then starts and runs normally. The pump, filter, lines, fuel pump relay, and ASD relay were replaced, spark is strong, and no relevant trouble codes are stored. Experts noted the short key-on pump run is normal and recommended checking the pressure regulator and the pump check valve for pressure bleed-down.
