AIR CONDITIONER
BRICODJONES
YEAH SO I HAVE NO MECHANIC EXPERIENCE WHATSOEVER AND I NEED SO HELP. i HAVE A 2002 DODGE DAKOTA SXT 4x4 WITH A MANUAL TRANSMISSION AND 68K MILES. IT IS A 6 CYLINDER ENGINE. THERE IS SOMETHING LEAKING INTO THE FLOOR BOARD ON THE PASSENGER SIDE. IT IS WATER, THEREFORE I FIGURE IT MUST HAVE TO DO WITH THE A/C. I THINK IT MAY HAVE SOMETHING TO DO WITH THE CONDENSTAION DRAIN LINE, MAYBE. COULD THIS BE CORRECT AND IF SO HOW DO I FIND IT AND HOW DO I FIX IT. MAYBE IT IS CLOGGED OR SOMETHING.
Jun 19, 2007 at 1:47 PM
A_DECENTMAN
I'm a NOOB, but I saw elsewhere on here a similar quesiton and the answer to it. The answer was pretty much what follows: It may be that your drain hose is plugged. This is found on the passenger side. Sometimes these getted clogged with gunk. Run a stiff wire up there and fish out the gunk and that should clear up the problem. Hope that helps.
Aug 6, 2007 at 1:14 PM
