My '98 Dodge Dakota with 138000 miles has started to run hot. I have had the cooling system flushed out and replaced the thermostat but this did not help. The coolant is not leaking out and it does not boil over but you can hear boiling sounds when the engine is turned off. It also seems to overheat faster if I make short stop and go again before it has a chance to cool. Also the warmer the ambient temperature is the faster it will over heat. Any idea on what the problem may be? Thanks
Jun 7, 2007 at 12:33 PM
