2008 Dodge Dakota Driver window
R_GINGRAS
Electrical problem
2008 Dodge Dakota 6 cyl Two Wheel Drive Automatic 11K miles
It happened about 6 month age, had my vehical parked in a sunny spot at work. brought it home for the weekend and noticed my driver window would not go down, all the other windows worked fine. Used my truck the following day and it work fine. Thought is was a thermal problem. After about a week it completly stopped working. Weather is cooling down and would like to use my window to get some fresh air. Thanks Rick
Sep 11, 2010 at 4:41 AM
SATURNTECH9
  • 30,868 POSTS
Your going to have to remove your door panel and see if your getting power and ground to the window motor.It sound's like you probably have a bad window motor but without pulling the door panel and checking for power and ground to the motor you won't know what's going on with it.
Sep 11, 2010 at 5:28 PM
