HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Dakota
Engine
Knock Sensor
Location
2006 Dodge Dakota P0325 Knock Sensor 1 Circuit Malfunction
RAZAMANAZ
MEMBER
2006 DODGE DAKOTA
V8
2WD
AUTOMATIC
32,000 MILES
Where is this sensor located on a 4.7L engine?
Tuesday, March 10th, 2009 AT 3:55 PM
THETOOLMAN
MEMBER
The Knock sensor is usually screwed into the block. I don't have access to the online manuals at this time. I will try to find a diagram to send you to be more exact.
Good Luck.
Thursday, March 26th, 2009 AT 9:03 PM
Please
login
or
register
to post a reply.
Related Knock Sensor Location Content
Where Is The Knock Sensor Located?
Where Are Knock Sensors Located On 4.7l V8
Asked by
framer42
1 ANSWER
2 IMAGES
2001
DODGE DAKOTA
1999 Dodge Dakota Knock Sensor
I Would Like To Know If The 1999 Dakota 3.9l Had An Egr Valve, And If So, Where Is It Located? Also, Where Is The Knock Sensors...
Asked by
dodge_richard
1999
DODGE DAKOTA
2002 Dodge Dakota Knock Sensor
Location Of The Sensor
Asked by
larrysweatt
2002
DODGE DAKOTA
Can The Computer Over Heat?
The Engine Light Came On And Had Someone Check And Found Four Things Come Up On The Computer. Two Days Ago The Temp Got Up To 109. Things In...
Asked by
raidenjames
1 IMAGE
2006
DODGE DAKOTA
Engine Wiring Diagrams Please?
Needed To Know What The Wire Is That Comes Out Of The Bottom The Distributor Cap And Where It Goes To. Truck Sat For A Few Months And Got...
Asked by
Justin Hamilton
21 IMAGES
1998
DODGE DAKOTA
VIEW MORE
Code Read Retrieval/Clear Mercedes-Benz C230
Code Read Retrieval/Clear Honda
How to Clear a Check Engine?
