2006 Dodge Dakota muffler
7,000 MILES • 6 CYL • 4WD • MANUAL
MARKESTE
There is black liquid leaking out of the mffler seam. I know there is typically some moisture when you start a vehicle, but this is dripping from the muffler. Is it just the muffler rusting through or is there a more serious problem? The trcuk only has 7,000 miles on it.
Dec 18, 2007 at 2:45 AM
CARLUCCIJA
  • 29 POSTS
That sounds like oil is getting in the exhaust. you may have put a batch of bad gas if you filled up using a gas container. It sounds stupid but i have met people who have done it. If not then you may have bad seals causing oil seapage into your exhaust.
Dec 18, 2007 at 7:52 AM
