2006 Dodge Dakota headlamp replacement
2006 DODGE DAKOTA
57,000 MILES • 6 CYL • 2WD • AUTOMATIC
KERRY2NUDES
How do I replace the headlight bulb. Drivers side of truck. Can I do from underneath and reach up?
Kerry
Feb 18, 2009 at 10:14 AM
  • 110,236 POSTS
Hi:
You need to remove the plastic grill around the light. Next, there is a steel (chrome) bezel that goes around the square headlight. I think it's held in with 4 screws. Once it's removed, the light will fall out for you.
I am correct... this does take the square headlight correct?
Feb 20, 2009 at 1:12 PM
