When driving the Dakota the ABS light and the Brake light engages when speed reaches 45 miles per hour. What does this indiciate?
Jun 19, 2008 at 10:33 PM
BMRFIXIT
✓Experienced Mechanic
A malfunction was detected
you need to check if you low on brake fluid
check brakes and if all OK you need the help of a scanner to determine the troubled area
good luck
