2006 Dodge Dakota ABS Light
2006 DODGE DAKOTA
17,000 MILES • V8 • 4WD • AUTOMATIC
GENIE53
When driving the Dakota the ABS light and the Brake light engages when speed reaches 45 miles per hour. What does this indiciate?
Jun 19, 2008 at 10:33 PM
BMRFIXIT
  • 19,053 POSTS
A malfunction was detected
you need to check if you low on brake fluid
check brakes and if all OK you need the help of a scanner to determine the troubled area
good luck
Jun 19, 2008 at 11:44 PM
