2006 Dodge Dakota
69,000 MILES • V8 • 4WD • AUTOMATIC
SLYNN9
06 4.7 dodge dakota magnum it run good but when i come up on rail road track go over them hard the truck will just die i will have to pull over and put it in park and start it and it will be ok whats going on thanks its going on now for two days no codes.
Sep 24, 2010 at 3:27 PM
  • 110,248 POSTS
That is a good one. Make sure the wiring harness to the PCM is good and tight. Also, check the crank sensor wiring to make sure it is tight and there is no wiring damage.
Let me know what you find. It sounds related to the electrical system and not fuel related.
Sep 24, 2010 at 4:08 PM
SLYNN9
i have try that and it was no good and it was trying to die on mt on the way home at the stop sign i was looking at the rpm and it was at 500 or just below it and it was try to so i give it some gas and it was good when i took off it may be rpm are to low may be. or fuel filter is dity. all i did i stop car was in front of me then it went then i stop fast and that when it did it?
Sep 30, 2010 at 12:28 PM
SLYNN9
Do you think it would be the iac motor?
Sep 30, 2010 at 3:16 PM
  • 110,248 POSTS
Yes, the IAC will affect the idle.
Oct 1, 2010 at 5:25 AM
SLYNN9
well look at it working ok.
this driving me up the wall i know a lot can ben it but i dont want to throw a lot of parts on and not fix it the problem beause it is not a good thing to do. got to be somthing iam over looking.
Oct 2, 2010 at 2:53 PM
  • 110,248 POSTS
If the IAC is good, have you checked for vacuum issues?
Oct 3, 2010 at 2:33 PM
