2005 Dodge Dakota upper control arm bushings
DRIVINGBLINDFOLDED
Suspension problem
2005 Dodge Dakota V8 Four Wheel Drive Automatic
How do I press the bushings out of the control arm wi thout removing the ball joint? also, if I have to remove the ball joint I still need the easiest way to press the bushing out.
Jul 31, 2009 at 6:49 AM
MERLIN2021
  • 17,250 POSTS
Go to Autozone and rent the ball joint press with control arm bushing press adapters. You can unbolt the arm from the frame leave ball joint connected, and swing the arm out towards the wheel well, then press the bushings and reverse the steps to reinstall it.
Jul 31, 2009 at 6:59 AM
