2005 Dodge Dakota lower control arm shock bushing
CWNICHOLAS
Suspension problem
2005 Dodge Dakota V8 Four Wheel Drive Automatic
while changing my shocks i had one that was siezed up because the lower bolt was rust welded into its bushing. i can find lower control arm bushings on the net but these are the bushings that connect it to the frame, not that connect the strut to the a arm. i already removed the bushing but now i need help!!
Mar 6, 2010 at 4:42 PM
  • 110,248 POSTS
The shock bushing is part of the shock. Didn't you get a new one with the new shock or am I missunderstanding what you are refering to.
Mar 7, 2010 at 5:48 AM
CWNICHOLAS
the shock bushing is not part of the shock on my truck. it is part of the control arm. the shock has 2 arms at the bottom that go around the bushing and a bolt slides through.
Mar 7, 2010 at 9:11 AM
