2004 Dodge Dakota water on floor board
2004 DODGE DAKOTA
HONEYB8300
Air Conditioning problem
2004 Dodge Dakota V8 Four Wheel Drive Automatic
think it is air conditioner drain but where is the drain?
Any other suggestions. I see this problem on a few search areas but can't find the solution.
Sep 5, 2010 at 2:02 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if certain it is water and not coolant than either door seals are bad or more likely the drain is clogged, it should be a drain tube coming out of the evaporator casing and going underneath vehicle. evaporator is behind passenger dash which is why the water will build up and poor out there if drain is clogged
Sep 5, 2010 at 8:07 AM
HONEYB8300
[quote:bc9cbf9c2d="bluelightnin6"]if certain it is water and not coolant than either door seals are bad or more likely the drain is clogged, it should be a drain tube coming out of the evaporator casing and going underneath vehicle. evaporator is behind passenger dash which is why the water will build up and poor out there if drain is clogged[/quote:bc9cbf9c2d]
It is water and doors are ok. Can you possible give the exact location of the drain for the air conditioner. We were not provided a manual when we purchased the truck - 2004 Dodge Dakota 4.7litre Have dried it out a couple times and had on hoist 2x but could not locater the drain tube.
Sep 5, 2010 at 10:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
there is actually a TSB (techincal service bulletin) over this issue. that means it's a very common problem with the particular vehicle and that there is a permanent fix for it provided by the dealer. TSBs are normally NOT free or covered on warranty though so check your local dealer about that. The evaporator drain hose runs through the fire wall behind the passenger dash. The dealer will seal the opening for the evaporator hose with RTV sealer as the fix.
Sep 5, 2010 at 10:22 AM
HONEYB8300
went to dealer they knew nothing about problem How does one get a copy of the TBS????
[quote:930ee6214b="bluelightnin6"]there is actually a TSB (techincal service bulletin) over this issue. that means it's a very common problem with the particular vehicle and that there is a permanent fix for it provided by the dealer. TSBs are normally NOT free or covered on warranty though so check your local dealer about that. The evaporator drain hose runs through the fire wall behind the passenger dash. The dealer will seal the opening for the evaporator hose with RTV sealer as the fix.[/quote:930ee6214b]
Sep 8, 2010 at 1:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
your local dodge dealer should be ashamed of themselves if they do not know about this issue.... a copy of the TSB is below..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2672.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_871.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname3_316.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname4_143.jpg
Sep 13, 2010 at 9:46 AM
