Climate control vent Stuck on defrost
118,000 MILES • V8 • 4WD • AUTOMATIC
JOHNDABBS
My air-conditioner is stuck delivering air through the windscreen outlet. Changing the selector to 'feet' or 'floor' does nothing. Any ideas?
Aug 15, 2010 at 11:08 AM
CARADIODOC
  • 34,413 POSTS
Hi johndabbs. Welcome to the forum. The actuators are vacuum-controlled. Check for a small black vacuum hose under the hood that is cracked or disconnected. The system is spring-loaded to default to the defrost position in case of a vacuum supply failure to insure you will have a clear windshield.
caradiodoc
Aug 15, 2010 at 11:44 AM
