2004 Dodge Dakota seal replacement
73,000 MILES • 6 CYL • 4WD • MANUAL
JOEWRIGHT3
Do you need to remove and open the gearbox to replace the rear old seal on the gearbox?
If not how is it removed?
Dec 7, 2008 at 3:36 AM
  • 55,797 POSTS
Hi, no you dont not need to disassemble the trans to repalce the rear seal, remove the drive shaft, remove the seal and install the new one and reassemble
Dec 8, 2008 at 5:22 AM
