2004 Dodge Dakota power steering problem
58,000 MILES • 6 CYL • 4WD • AUTOMATIC
MRUBADO
takes 2 hands to turn left or right and if you let go of wheel it will stay turning won't come back unless you bring it back.had a mechanic tell me power steering pump shaft might be broken.said to take off belt and see if shaft could be pulled in and out pulling on pulley.there is some play back and forth.is this normal or should there be no movement at all.he didn't say how much play.also how easy should it be to spin the pulley
Aug 9, 2008 at 6:06 AM
2CARPRO JACK
  • 11,533 POSTS
A small amount of play is mormal, around an 1/8 inch.Any more than that and it may have a broken shaft in the pump.
Aug 13, 2008 at 9:50 AM
