2004 Dodge Dakota oil pan leak
2004 DODGE DAKOTA
44,200 MILES • V8 • 4WD • AUTOMATIC
MAILMANJOHN
Oil pan leak. Not the gasket or drain plug. Have a leak off the bottom of oil pan due to corrosion. Small drip & keeping an eye on oil level. Short of replacing the oil pan, any suggestions on pluging a small hole until I can get it into the garage. Thanks
Sep 30, 2008 at 10:31 AM
FOX_RACER627
  • 12 POSTS
Clean the area real good and put some putty in the hole. then cover it all up with JB weld. Should hold up for a while, may not be pretty but it stopped the leak on my transfer case. Hope that helps.
Sep 30, 2008 at 3:41 PM
