2004 Dodge Dakota no back up lights
56,000 MILES • V8 • 4WD • AUTOMATIC
NASCAR1953
I do not have reverse (back-up) lights when I put the truck in reverse. I checked all fuses and replaced both bulbs.
Could someone help?
Thank You
Rick N
nascar1@embarqmail.com
Nov 1, 2008 at 8:13 AM
  • 110,248 POSTS
Hi:
There is a switch on the transmission that may be bad. Locate the switch on the side of the transmission and determine if it's getting power with the key on. If it is, place the truck in reverse (making sure someone holds the brakes) and check for power out. If there is no power out, replace the switch.
Nov 1, 2008 at 3:14 PM
