2004 Dodge Dakota engine
73,000 MILES • 6 CYL • 2WD • AUTOMATIC
MRBRYANBAUER
when i started my 2004 dodge dakota this morning there was (and still is) a loud "lawn mower type motor" noise coming from the engine near the belt. it is significantly loud and was very alarming. i'm not the most vehicle savvy person. wish i was. FYI- i am in a definite need of an oil change...pretty black oil. transmission fluid is nice a red. thanks for the help
Apr 27, 2008 at 3:53 PM
BMRFIXIT
  • 19,053 POSTS
did you check the oil level
you need to do so and add if needed
also you need to have truck checked
i wouldn't drive much with out having it checked
Apr 27, 2008 at 11:22 PM
MRBRYANBAUER
after changing the oil and playing with the accelerator a bit, the oil pressure level normalized...bad fuel pump i think.
Apr 28, 2008 at 7:39 AM
BMRFIXIT
  • 19,053 POSTS
fuel pump is in the fuel tank
bad fuel pump will cause a no start
Apr 28, 2008 at 9:57 AM
MRBRYANBAUER
i apologize. i meant to type OIL PUMP....
truck seems to be running normal now. the engine isn't knocking anymore, oil pressure is normal...i'm going to keep a close eye on my oil pressure. thanks for catching that.
Apr 28, 2008 at 1:18 PM
