Electrical problem
2004 Dodge Dakota V8 Two Wheel Drive Automatic 70k miles
My cruise control will not turn on at all. I have replaced the switch on the steering wheel -- didn't fix. Last year it would turn on but would switch off for no apparent reason then it just stopped turning on alltogether.
Not sure if i should change the servo ($90.00) or switch out the brake light switch ($20.00) or is there something else causing the problem. My airflow works fine- defrost/vent/floor- so I do not think it is a vacuum problem.
The shop wants $100.00 plus to figure out the problem.
Mar 12, 2010 at 5:25 AM
