Airbag light
KTRUMBULL
My airbag light stays on and the push pad on the steering wheel will not activate the horn. but the horn works with the key pad could this be a clock spring?
Sep 7, 2008 at 3:50 AM
CARADIODOC
  • 34,413 POSTS
The horn not working is a great observation that most people miss. You are likely to find the cruise control also doesn't work or will stop working soon. Those are all signs of a broken clock spring.
The place to start is by having the diagnostic fault codes read and recorded. Simple fault code readers usually only read codes in Engine Computers. Some of the better ones also read codes in a few other computers. You can try visiting some auto parts stores where they read codes for free, but if they can't read Air Bag Computer codes, you'll need to visit a mechanic. Almost all independent repair shops can do that for you.
If the clock spring is broken, the fault code is going to be something on the order of " Open Squib" or "Open Initiator". Both of those refer to the circuit the computer uses to fire the air bag. The clock spring is part of that circuit.
If the clock spring is suspect, here's links to some related articles you might find helpful:
https://www.2carpros.com/articles/symptoms-of-a-bad-airbag-clock-spring
https://www.2carpros.com/articles/air-bag-removal-steering-wheel
https://www.2carpros.com/articles/steering-wheel-clock-spring-removal
Dec 2, 2020 at 3:15 PM
