2004 Dodge Dakota A/C fan switch works only on the highest
DNORANHO
  • 2004 DODGE DAKOTA
  • V8
  • 48,500 MILES
What could be wrong? When turning on the Air conditioning, the fan switch needs to be set to its highest level for it to start blowing cold air. If turned one notch lower, it cuts the blower off and the cold air too.
I think its the fan switch thats defective. If I am wrong, could you give me diagnosis or what it could be before I take it in for fixing.
Thanks
Thursday, July 17th, 2008 AT 8:46 AM
DOCFIXIT
  • 18,828 POSTS
Most likely the blower resistor is bad. Located behind glove box just down from blower wire connector held on by couple screws. Put test light on it move fan switch through the speeds if you get volts then resistor is bad.
Good luck
Thursday, July 17th, 2008 AT 9:08 AM
