2004 Dodge Dakota
2004 DODGE DAKOTA
28,000 MILES • 6 CYL • 4WD • AUTOMATIC
T BURKE
have 2004 dodge dakota 28000 miles check 4wd light on wont switch from 2wd to 4wd its a automatic any answers and would this be covered under manufacters warrenty
Oct 21, 2008 at 12:32 AM
  • 110,236 POSTS
Hi:
It is most likely a vacuum problem unless the vehicle has a push button to ingauge the 4X4. If it does, it could be the switch or the motor which switches the transfer case. As far as the warranty is concerned, it would be based on what is causing the problem.
If you have any specific questions, let me know.
Oct 21, 2008 at 4:15 AM
