2004 Dodge Dakota
30,000 MILES • 6 CYL • 4WD • AUTOMATIC
THEBICK
blower unit on heater and air conditioning quit,it is not a fuse, could it be the switch on the panel
Oct 3, 2008 at 6:36 AM
  • 110,251 POSTS
Hi:
Yes it could be the switch, but before replacing it, I suggest some test be done. First, find the blower motor resostor on the firewall under the hood. I believe it's on the top of the firewall, passanger side. It will have several wires going into a plug. Once located, unplug it and using a test light, check for power to the resistor by turning the key on and the fan switch. If there is power there, you have two choices. First and easiest, replace the resistor. It's a cheap part and if it's bad, it will save you a lot of work. If you replace it and the blower still doesn't work, the motor must be bad. It's located under the dashboard on the passanger side. You will need to remove part of the dash assembly to get to it.
Let me know if you get to this point, and I'll tryto guide you through it.
If this helps, let me know or if you have additional questions, let me know.
Oct 21, 2008 at 12:25 PM
