2004 Dodge Dakota
72,000 MILES • V8 • 4WD • AUTOMATIC
NANOELITE6
trieng to refill the refrigerant in my a/c but the only valve i have is on the silver cylinder object? i checked the lines going to the compressor and there isnt a valve on either of them so i dont know where i should put it?
Apr 15, 2010 at 5:50 AM
CH112063
  • 1,320 POSTS
R134 goes into the low side. Always. It is the side with the larger threads, its blue. Or the larger sixe threads. You can't miss as even if your using a manifold set, you use the blue side. ok
Apr 15, 2010 at 1:57 PM
