2003 Dodge Dakota Whining noise when I start driving
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
JARRETTKENSETH
Does a 2003 Dakota have a speedometer cable?
My truck is making a whining noise that increase with speed, then stops once I reach 40 or so. It doesn't make the sound when just idle. I was told it may be the speedometer cable, but I didn't think 2003 had those. Open to any advice!! Thanks
Apr 4, 2008 at 11:51 AM
MASTERTECHTIM
  • 4,750 POSTS
no speedo cable. does noise change when on and off the gas? does it change when turning left or right?
Apr 4, 2008 at 12:04 PM
JARRETTKENSETH
Yes, it changes pitch with acceleration. Haven't noticed it changing with turning. Brakes are fine. Drive shaft and belts are fine.
Apr 4, 2008 at 12:11 PM
MASTERTECHTIM
  • 4,750 POSTS
i have replace a lot or rear end pinion and side carrier bearings for making the same kind of noise. best bet is to have a tech road test it for you to know for sure.
Apr 4, 2008 at 12:21 PM
