2003 Dodge Dakota throttle position sensor or transmission
102,000 MILES • V8 • 4WD • AUTOMATIC
SCHNOEBELEN.ME
when going at a steady speed rpm guage will go up slightly approx. 250-300 then back down doesnt fill like trainsmission is jerking or engine being (dragged down) had trainsmission flushed and filled also changed both filters @ 90,000 engine has new OEM plugs and all routine maint.
Dec 22, 2009 at 8:10 AM
RACEFAN966
  • 5,029 POSTS
Well it sounds like the transmission torque convertor is locking in and out of OD. This will change the rpm about 2-300 rpm as you say. Does this happen more at any paticular speed? Do you have access to a scan tool?
Dec 23, 2009 at 1:59 AM
SCHNOEBELEN.ME
Responding to your question,it happens when cruising @55 or 65 depending on H-way or Interstate . Also I've noticed that shift points are slightly higher than normal, but are still smooth shifts . What should I do ? Yes, I do have a scan tool. No check engine light has come on or no pending codes.
Dec 26, 2009 at 7:04 AM
RACEFAN966
  • 5,029 POSTS
Ok this could be the TPS or the vehicle speed sensor. So tell me is there any codes pending or otherwise?
Dec 28, 2009 at 11:34 AM
