2003 Dodge Dakota oil filter
2003 DODGE DAKOTA
48,000 MILES • V8 • 4WD • AUTOMATIC
DANA DRUIVENGA
how important is it to have the exact size (recommended size) of oil filter for one's vehicle? would a 1/2 inch difference in length significantly change the oil pressure in the engine?
Apr 12, 2008 at 2:06 AM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there,
as long as the filter fits correctly, there is not a real problem in how big it is, some vehicles use small oil filters just for access reasons only, all that is affected is the amount of filter surface area available to clean the oil,this is not a big problem if you service your engine regularly, it has no bearing on oil pressure at all.
Mark (mhpautos)
Apr 12, 2008 at 3:19 AM
