2003 Dodge Dakota no start
2003 DODGE DAKOTA
GORD870
Electrical problem
2003 Dodge Dakota 6 cyl Two Wheel Drive Automatic
good battery good starter no lights in dash no start no click and display shows no bus need help
Mar 11, 2009 at 12:05 PM
THETOOLMAN
  • 123 POSTS
Did you have it checked for any DTC? Have you checked the connection that plugs into the back of the instrument panel? In fact I would unplug and then plug it back up to make sure it is good and tight. Be sure to disconnect the negative battery cable before you mess with it. Be sure and check for DTC's before you disconnect battery. Also look for any grounds that are loose or disconnected. The bad thing is if it isn't a loose connection and or fuse this may be pointing to a bad PCM. Hopefully just a loose connection.
Good Luck...
Mar 26, 2009 at 1:48 PM
GORD870
went back next day hit the unlock button on remote to get in tried starting it and the damn thing fired right up and hasn't had a problem since thanks for the info if in future problem comes back i will try that i do know there was no dtc's though but thanks
Mar 26, 2009 at 2:55 PM
