2003 Dodge Dakota Inermittent over heat
2003 DODGE DAKOTA
108,000 MILES • V8 • 4WD • AUTOMATIC
RSG
Just checking the the technology used by my mechanic to determine the cause of my dakota overheating. He advised there was a chemical he puts in the antifreeze to see if any exhaust gases are present in the cooling system. Said if so, the chemical or antifreeze changes color to indicate a head gasket or cracked head/block... Is that something you can confirm? Is that possible? Is there such a chemical?
thx RS
Jul 1, 2008 at 5:23 AM
Yes they called it bloc check-to confirm exhaust gases entering the cooling system and the tester fluid will change color
Jul 1, 2008 at 6:29 AM
