2003 Dodge Dakota heater does not work
19,500 MILES • V8 • 4WD • MANUAL
RINGO
It started when the heat or a/c for that matter stopped working on the low setting on the control switch, then it stopped working on the medium setting and finally stopped working all together. I have already changed the blower motor thinking that was the problem and apparently it wasn't. I was told it might be the control switch I'm not sure what the problem could be.
Jan 16, 2008 at 12:11 AM
BMRFIXIT
  • 19,053 POSTS
[quote:78a744e09c="ringo"]Heater problem
2003 Dodge Dakota V8 Four Wheel Drive Manual 19500 miles
It started when the heat or a/c for that matter stopped working on the low setting on the control switch, then it stopped working on the medium setting and finally stopped working all together. I have already changed the blower motor thinking that was the problem and apparently it wasn't. I was told it might be the control switch I'm not sure what the problem could be.[/quote:78a744e09c]
check blower motor resister
check fuses and relay (under hood power box)
Jan 16, 2008 at 12:24 PM
