2003 Dodge Dakota Heat Blower
141,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOHN ROWLEY
I have a 2003 Dodge Dakota and the blower for the heat quit working. Any idea what might be causing this. I checked the fuses and they appear ok.
Nov 22, 2008 at 10:14 PM
BMRFIXIT
  • 19,053 POSTS
Check fuses again and relays
place switch at high
locate blower motor connector and unplug it
test for ground and battery power
replace blower motor if you have both
check wiring and ignition switch if not
I would suspect blower motor
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 22, 2008 at 11:22 PM
