2003 Dodge Dakota Fr end click noise while in a turn with b
62,000 MILES • 6 CYL • 2WD • AUTOMATIC
SALMANILLA
6 months ago I replaced front hub assemblys since I had to remove brakes I replaced the pads only. About a month ago I started hearing click noise in the fr end while in a turn only with brakes applied . No noise while turning with brakes released. I think i need to re do the brakes and make sure the slides are greased properley. I was just looking for a second or third opinion.
Thanks
Nov 29, 2008 at 4:56 AM
DOCFIXIT
  • 18,828 POSTS
Yes good place to start also check CV joint for excessive play.
Nov 29, 2008 at 5:56 AM
SALMANILLA
Thank you for your opinion I'll start working on it as soon as I get a dry day and I'll let you know how it turns out.
Nov 29, 2008 at 9:03 AM
SALMANILLA
Docfixit,
Just wanted to let you know that the noise is gone.
I removed my brakes cleaned,greased pins,and applied disc brake quiet to the back of the pads and everything is working great now. Thanks again for your response.
salmanilla
Dec 6, 2008 at 9:05 AM
DOCFIXIT
  • 18,828 POSTS
Your are very welcome and a good diagnosis you did not jump to conclusion you stayed with basics.
Dec 7, 2008 at 5:40 AM
